Debugged
A project log for Trinity Core and Net
A 32 Bit Variable Length Instruction Set Core and Transputer Like Comms Network
andre-powellAndre Powell 04/08/2019 at 22:010 Comments
The smaller 2 D Trinity Net by the looks of it is up and running. A couple of squeaks but wasn't too bad.
Did notice a couple of possible improvements along the way so will target those next.
Getting this up and running means that I will be able to get an array into the larger FPGA board.
I would prefer to get this all tested out and secure before concentrating on the RS232 again. With that good to go I can start to write some code and get it to deploy to the array.
I've also bought a four line LCD display which will be used by the master to display information. This implies four machines but might be able to use two to a line.
Slow but sure.
