Serial inout now working
A project log for AlphaNumDisp
another display
alexAlex 02/01/2016 at 16:551 Comment
So after the basic firmware which I did first for testing, I did now expand that a bit. Now characters received over the the UART interface are shown on the display. The characters a decoded as normal ASCII characters. After some trouble this is also working stable. Thinks that gone wrong:
Some ideas for a next revision:
So here is a picture showing some test letters. The board in the front is a normal USB to UART converter.
The characters sent here are:
Test#7
One good thing about using the serial interface is that you get a display which is compatible to a huge number of devices.
I did also add a link to bitbucket repository. There you can find the early firmware version of today.
davedarko wrote 02/01/2016 at 17:12 point
you should always make them chainable, especially when you always get 3 boards from OSHpark ;) next time we'll see we should start a badge/nametag war :D
