Yup, I made another revision
A project log for Atmega328P Target
Yet another dev board for the Atmega328P
mcunerdmcu_nerd 01/08/2019 at 20:420 Comments
I went ahead and made yet another revision of the board,1.3.
Changes made:
Added a plane for VCC
Added a jumper for the power LED (useful for low-power projects)
Made many pin header pads larger for easier soldering
It's looking really polished now.  The only downside is by adding a power(VCC) plane it does take some additional dwel time with the soldering iron to solder some of the pins/pads (very noticeable when I soldered the power pins on the Atmega328P, but not terrible.)
I did the two-part technique for soldering on the Atmega328P; first soldering the chip on with and iron and then adding additional flux again and going over with with my hot air station.  As Dave would say, looks like a bought one.
