Designing an enclosure
A project log for blink(inch)
Clone of the blink(1) indicator light with ATTiny85 and V-USB
sprospro 12/11/2015 at 08:510 Comments
Starting with a fork of the ATTinyTemp enclosure i created a rounded cube enclosure for the blink(inch) in OpenSCAD. It is just a bit larger than an inch^3, and thanks to the original parametric design the only real effort went into making sure the hole for the USB plug was the right size.
