SITL
A project log for QuadRotor testBed for localization and mapping
I am trying to build a test bed for trying out localization and mapping algorithms.
int-smartint-smart 07/11/2018 at 12:290 Comments
Currently I am working with simulating the project in ArduPilot and then taking it to hardware. ArduPilot SITL is one way to simulate the flight and the sensors. I am pretty sure that the SITL does have a Laser scanner simulator but am not sure what is its field of view. The process to download and run SITL on a Ubuntu 16.04 is as follows:
git clone git://github.com/ArduPilot/ardupilot.git
cd ardupilot
git submodule update --init --recursive
cd ardupilot
cd Tools/scripts
./install-prereqs-ubuntu.sh
export PATH=$PATH:$HOME/ardupilot/Tools/autotest
export PATH=/usr/lib/ccache:$PATH
. ~/.bashrc
cd ardupilot/ArduCopter
sim_vehicle.py -w  #to load the default parameters
sim_vehicle.py --console --map
 The copter can be run in several modes:
1. Guided: To run in Guided mode do the following.
mode guided
arm throttle
takeoff 40
For more detailed commands and information goto:
http://ardupilot.org/dev/docs/copter-sitl-mavproxy-tutorial.html
2. Auto: For navigating the copter in Auto mode do the following:
wp load ..\Tools\autotest\copter_mission.txt
arm throttle
mode auto
rc 3 1500
