DHT
A project log for IoT - Clock
Clock, based on a adafruit neopixel ring and particle photon
tilloTillo 12/15/2015 at 23:320 Comments
Since I had a DHT sensor at home and this clock needs wifi anyway, i tought i can use the sensor to measure temperature and humidity and put it to thingspeak. It's done way to often I know, but not at a clock.
Plus, because of 60 neopixels I decided to place the sensor on the outside. Gives the case a hacky look.
Code will be updated when it runs fine.
