Shaft Drive
A project log for Mr Stabby
A reciprocating Hysteria Machine
boris-van-galvinBoris van Galvin 12/16/2015 at 03:230 Comments
The shaft is made from stainless steel hex rod and is pinched between the stepper drive wheel and two guide wheels, the pinch wheel has a rubber sleeve to allow it to grip the shaft. The stepper is also on a pivot and a tension spring puts enough force to allow it to move however it it jamms it will either skip steps or slip on the shaft.
