Gear motors mounted
A project log for Jimmy the mouse bot
I'm building a mouse bot based on the Parallax Propeller microcontroller.
jay-tjay-t 10/19/2014 at 12:290 Comments
Finally I mounted the two gear motors and wheels. Mousey now can drive.
I wrote a little control program in Tachyon Forth, so Mousey uses it's IR sensors to avoid obstacles. This is just the first step to improve the program further.
