Prototype Mark Two
A project log for KSP Gegi
Kerbal Space Program physical status and control panel
maciej-witkowiakMaciej Witkowiak 12/31/2015 at 13:250 Comments
The second prototype is ready. I still have only a vague idea how to mount OLED display and joysticks. At the moment they are fastened with brass M3 screws.
I have also made small notches on the back side so that potentiometers and switches won't rotate.
I decided not to use thumb knobs that came with the joysticks. I drilled 2mm holes in wooden pegs and I put them on the joysticks' shafts. This way I have better control and precision over the joystick movement.
The tests revealed some flaws in the software that need to be fixed:
The hardware needs some further work too:
Of course I also have to rewrite Python interface between serial commands coming out of the panel and kRPC.
