3D printed robotic arm- dairy
A project log for 3D printed robotic arm
This is a project inspired by @andrias, We will try to print it and later edit the design.
abd-el-rhmanAbd-el-rhman 01/04/2016 at 00:380 Comments
Today I started to:
- learn file extension types .ipt and .dwg
- downloaded autocad 2016 to view the robot design and got licensed.
- couldn't open because I needed inventor to view the parts and assembly files.
- got with @sai and sat a meeting to discuss our target
- viewed the forearm design with a360 online viewer and measured the dimensions.
- ordered the 3D to be printed (will decide tomorrow)
To do:
- get inventor, view the design, try to readapt the design.
- find other 3D printers able to get the original design.
- order the ball bearings, motors and nuts.
- keep track of the whole project.
Today,
We have installed inventor 2016 to our
Windows pcs so that we can view the design.
- we started reading and listening to Tutorials describing the main features of inventor 2016.
We set the target to reduce the current design to 80% of it's size now.
-Regarding screws and motors we will maintain them as the original design was too heavy to be powered solely by Nema11 and Nema 17.
- our next move is to keep learning about inventor and try to reduce the size of the design with maintaining the same size for the motors..
-another approach is to look for a bigger 3D printer that can print the original design with lighter materials.
3rd jan (Happy new Year 🎉🎉🎉🎉 Malik
I have completed the Inventor tutorial and heading towards editing the master design..
My plan is to edit the base items first and print them.. Then evaluate
End.
4th jan
today I successfully edited the motor extrusion and uploaded the scaled base-segment.ipt file and the base with the Nema17 motor.iam file here.
end
