Improved hoses
A project log for JigSolve
A pick n place machine to finish jigsaw puzzles
dan-royerDan Royer 01/22/2016 at 20:437 Comments
https://www.marginallyclever.com/2017/01/jigsolve-improved-hoses/
anthony.webb wrote 01/25/2016 at 07:54 point
Hey Dan, you might be able to use an idea similar to the bracket I use for the rotational steppers on my pnp project: https://hackaday.io/project/9319-diy-pick-and-place/log/30784-unlocking-your-nozzle-stepper
This way your hose can stay fixed, and the nozzle can rotate freely.
Dan Royer wrote 01/25/2016 at 08:57 point
did you drill a hole the length of the stepper shaft?! That must have been expensive
anthony.webb wrote 01/25/2016 at 16:04 point
http://www.robotdigg.com/product/43/Nema8+Hollow+Shaft+Stepper+Motor Nah, not too expensive. They make steppers for this kind of thing, although you wouldn't have to use on like this, could adapt your existing design.
chev1955 wrote 01/24/2016 at 14:07 point
Hello Dan
just go back in town saw jlg puzzle had to respond fat short syringe sitting on top
of suction cup pulling vacuum with rc servo ,stepper motor.or ??? eliminate hose.
eliminate rotation problem.
sarasota fl
steve    chev1955@comcast.net
Dan Royer wrote 01/25/2016 at 04:04 point
I can't parse those sentences.
chev1955 wrote 01/24/2016 at 14:06 point
Hello Dan
sarasota fl
chev1955 wrote 01/26/2016 at 23:46 point
Dan sorry for babble above i was talking to myself  not the first time.
think my last message got deleted. I have been dealing with peristaltic
pumps 15 yrs. to clean print heads. one of these top of Anthony's hollow shaft stepper could do the trick? 10 15 bucks on ebay. steve chev1955@comcast.net
http://www.ebay.com/sch/i.html?_odkw=peristaltic+pump+tubing&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR10.TRC2.A0.H0.Xperistaltic+pump+.TRS1&_nkw=peristaltic+pump+&_sacat=0
