Hackaday.io Hackaday.io
Sign up Log in
Battery upgrade for a dremel
I bought this dremel for 40 bucks a few years ago, now it worked great up until the battery life declined drastically. I then upgraded it
solderkingSolderking
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.1k
0
4
2
Team (1)
  • solderkingSolderking
Join this project's team
  • Video of the build
hardware
completed project
Dremel
Related lists
Hobby
Just for fun
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/10/2016 and last updated 10 years ago.
Description
My dremels battery had finally had enough. It wouldn't hold a charge for more than a few minutes. Most of what I do requires a dremel, one that works. So, I did what any hacker would do. I looked around for alternative power methods and found a drill that I no longer use. This drill had a few 1.2 volt nicd cells that were all ran in series to create 12 volts. I took the battery pack apart and removed all the cells. Then made my own battery pack using 8 of the cells. I ran two cells in parallel then in series with another two cells in series. I did this twice. So there are 2 sets of batteries at 2.4 volts each. With the flick of a switch I can pick either one pack at 2.4 volts or both packs at 4.8 volts for high speed. I covered the entire build in the Youtube video below.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Transform Your Dead Scooter To A Dewalt Battery-Powered Electric Scooter!
Project Owner Contributor
DeWalt Powered Electric Scooter
carlni2008carlni2008
How I converted my electric bike battery from Sealed Lead Acid (SLA) to Lithium Iron Phosphate (LiFePO4).
Electric Bike Battery SLA to LiFePO4 Conversion
lucas-rangit-magasweranLucas Rangit MAGASWERAN
Simple adapter to convert Dewalt battery packs to a useful barrel connector
Dewalt Battery Adapter
vitor-de-miranda-henriqueVitor de Miranda Henrique
600Wh portable battery made of 18650 cells with an included 1000W inverter
600Wh Battery Box
diego-vDiego V
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Battery upgrade for a dremel", please tell us the reason.
Send message
Remove Member
