Posted at 11/30/2017 5:47:31 PM
A project log for Watchdog Security Camera Robot
Solar charges, Open build, affordable, watch and report or community presence robot.
josh-starnesJosh Starnes 03/22/2018 at 17:240 Comments
Ok so I started by attaching the sensor stalk to the top of the battery cover, I used Liquid nails clear first after scuffing the plastics on both parts. I used Liquid nails because it is very thick and I needed to center and balance the tube into the correct position. The thick viscosity holds the part in place after I center it. I needed to completely cover the hole where the seat mount was and also level it. So I eye balled it till I liked where it was. I will also put some screws in it later when it is reinforced with fiberglass cloth. It needs to be able to withstand being kicked or falling over on its side without significant damage.
