We figured out the RFID bit!
As usual,you can find everything you need to build this on the internet.
Here's a very fuzzy video of it in action:
This in not a brute forcer yet. My tag had the data on it just printed on the back.
It was just a matter of transforming from decimal to hexadecimal and pasting that in the arduino code.
edit: I own the intercom and tags. Please don't do this if you are not permitted.
[ E C C 0 ]
PMercier
rossumur
Sophi Kravitz
I know where you can buy a serial and parallel port for the portfolio two companies http://www.best-electronics-ca.com/portfoli.htm and also http://www.myatari.com/ataripor.txt
Hope this helps
