Getting usable images with a 500$ DIY ultrasound machine
A project log for Murgen: open source ultrasound imaging
An open-source ultrasound imaging dev kit side project
kelu124kelu124 • 03/29/2016 at 08:12•3 Comments
Another couple of hours worth of playing - full lab log on github (Session 6) !
We finally get some images from the fantoms (that is, condoms filled with agar gel and tapioca balls).. and below is the setup, upper left the clinical image (coming from a 100k$ machine) and our image (lower). We clearly see the bigger tapioca balls (orange circles) and smaller (blue marks).
Mission accomplished =)
Same type of config, from a different angle: seeing low diffusion areas =)
Last but not least, the noise (circled in red) is due to the bitscope itself, I'm getting a USB isolator to get rid of this damn noise.
A full image
kelu124 wrote 04/07/2016 at 21:32 • point
Hey Jan, just posted new images, less noise, and a scale :)
Jan wrote 03/29/2016 at 10:12 • point
Thats purely amazing progress! Keep up the good work!
Just curious: Is the image resolution tied to the sensor/hardware or can we expect
images with higher resolution soon?
kelu124 wrote 03/29/2016 at 12:05 • point
Many thanks for your comment Jan !
The sensor we're using is not perfect, and we have a really cheap servo.. However, as a first step, the resolution could be made better with another algorithm to improve the spatial resolution in the lower part of the image. There are raw data files, and a python framework.. would you be up for the challenge? :)
With this two, I'm curious to see what are going to be the next generation of images!
