Drawing with ultrasounds
A project log for Murgen: open source ultrasound imaging
An open-source ultrasound imaging dev kit side project
kelu124kelu124 07/04/2016 at 09:110 Comments
What happens if you have a 1D sensor capturing data, with a moving object? Like the Slit-scan cameras, which give a surreal feeling to portraits for example:
Well, you can also do this with ultrasounds =)
