Pendulums and hall sensor tested
A project log for Mini Analog Quadcopter
Who needs bits and bytes to fly a quadcopter.
jlamJLAM 05/16/2014 at 13:250 Comments
Made a pendulum with a magnet attached to the bottom and tested the hall effect sensors. One thing to note is that by moving the magnet in the right direction I was able to get an increase and decrease of the motor speed with varying angles. Another thing I tried was dampening with a sheet of Al plating. This worked well even with a hole cut in for the hall sensor.
