Breadboard Extenders
Just my way of making my breadboard life a little easier
I saw this project: and thought I'd share my way of making my breadboard life a little easier
These 2 extenders are all I have so far. For these 2 I am using the Breadboard Prototype PCBs available at Radio Shack (276-0150). The one with the switches on it also has several female pins soldered to the board so that the switches can be configured with a pull up or pull down resistor. These resistors can be changed as needed. The switches I got from Electronic Goldmine a few years back, they were 5.00 for a bag of a 100. I have them mounted on their backs as opposed to their feet which faces the bus lines.
The extender with the LEDs on it has one set of LEDs (8 red ones) that are hooked with the same female pins put are used individually with a resistor mounted on the board via the female pins. I use the female pins to put the resistor in so it can be changed if need be. The other set of LEDs are the clear ones, but light up green. There are 11 of those on their side of the board and they use the 2 center bus lines to connect to. Again I have the female pins soldered to the board so that the leds can be used from the gnd bus or the VCC bus with a dropping resistor and another point to actually control the LED.
The female pins are from amazon:
Well it seems Amazon has gone crazy about the way they are pricing these female headers. I got 10 for 7.91 back in 2014. The prices on amazon seem to be out of control as of now (1/24/2016).
Just need to take this and set it up for a few switches on a single board and possible an enclosure or frame to mount the board to.
JPEG Image - 8.91 kB - 04/14/2016 at 02:36
The bottom view of my 10K linear potentiometer board.
JPEG Image - 333.45 kB - 03/09/2016 at 01:47
This is the basic layout for the Radio Shack Prototype PCB cat # 276 - 0150 for ExpressPCB
pcb - 13.75 kB - 01/27/2016 at 03:45
LED - Bench Accessory 002.pcb
This is the RED LED layout side of the breadboard extender. Use in ExpressPCB
pcb - 21.20 kB - 01/27/2016 at 03:45
This is the layout for the switch breadboard extender. Use in ExpressPCB
pcb - 22.78 kB - 01/27/2016 at 03:45
View all 8 files
  • Maybe a better way to deal with switches
    cyplesma04/14/2016 at 02:34 0 comments
    Spent a little time working out a way to make a configurable pulled up/down switch. Just need to get as many as I can on a board. Was using my switch board tonight and didn't like having to make all those little connections. So I think I'll have to do this idea.
  • Dreaming & Scheming
    cyplesma01/28/2016 at 17:40 0 comments
    use one of the square prototype boards to make a 555 timer (clk) circuit, maybe use male header pins to plug into breadboard. (more of a wiget/extender combo)
View all 2 project logs
cyplesma wrote 03/09/2016 at 01:45 point
just added one of 2 boards I use for potentiometers.  This as noted on it is for 3 10K linear potentiometers. The second one is for 3 100K linear potentiometers which is currently in use on a breadboarded battery desulfator circuit currently doing its job on a battery.
Stefan Lochbrunner wrote 01/24/2016 at 11:47 point
Are those female headers really almost 7$ for only one 1x40 header? If so, I'd suggest buying them off of eBay.
cyplesma wrote 01/24/2016 at 16:43 point
I paid 7.91 for 10 pieces back in 2014. Seems they have gotten ridiculously priced on amazon these days.
