Try eXaDrums on your PC!
A project log for eXaDrums
Electronic drums for Linux
jeremyJeremy 03/08/2017 at 15:170 Comments
Did you know that you can try eXaDrums on your PC?
Actually, this feature was there at the very beginning, but it wasn't easy to use. Now it's pretty easy. I updated the instructions (step 8) so that they explain how to read sensors data from your hard drive. As described in the instructions, you can set the sensors to "Hdd" mode and specify the files path.
That makes eXaDrums very easy to install on a PC, as you only have to execute the script that is provided in the files section, and configure the "Hdd sensors".
I intend to work on the triggers configuration as well and some other things, but the really exciting stuff will be the rhythm coach. I'll keep you guys informed!
