I was working with my son on his science project “Impressed Current Cathodic Protection in Presence
of AC Interference.” Impressed current cathodic protection is used to
protect pipes (oil, gas, water lines) from rapid corrosion. Rectifiers are used more than any other source of
impressed current power. Cathodic protection is a method of supplying electrons
to a pipe such that when chemical corrosion processes occur at the surface of a
pipe the pipe will not shed any electrons, but rather the cathodic system will
supply electrons from an external power source, rectifier. It is often a
difficult task to determine just the right amount of protection. One of the
critical components of the experiment is the soil resistivity. Soil resistivity
determines the amount of current flow from pipe into the soil. Higher soil
resistivity results in lower currents flow. Basically pipe will corrode faster
in wet soil than in dry soils or sands. I needed to measure soil resistivity
and regular multimeter gives Open Line because it supplies DC current to the
soil and soil gets charged like a capacitor. Multimeter + on the other hand
measured soil resistivity very accurately. The reason is that instead of
supplying DC current, Multimeter + sends a sort pulse during which it takes
resistance measurement. After the reading is taken, pulse value drops to zero potential
and soil has enough time to discharge. Then the process is repeated.
Roman
