I'm finally done building my CNC mill. For the past half year I've been buying the parts and machining the structure out of 1/4 in thick steel plate on my "bigger" manual mill, a ZAY7040.
The machine characteristics are:
- Weight: 55 kg/ 120 lb (99% steel)
- Rapids: up to 400 ipm/10 000 mm/min
- Motors: 24 V 20 W output power at maximum efficiency brushed motors (60 W maximum output power)
- Linear motion: 12 mm diameter 4 mm lead ballscrews, 12 mm linear rails, back to back angular contact bearings on the fixed side, deep groove bearing on the floating side, spider couplings for the motors
- Travel: 160 x 120 x 80 mm (X,Y,Z)
- Spindle: 800 W 220 VAC three phase synchronous motor
- Motor driver: pretty obvious :)
- Machine controller: Beaglebone running machinekit with a custom cape for the signal connectors, e-stop, limit switches...
![](https://cdn.hackaday.io/images/5756281469315092000.jpg)
![](https://cdn.hackaday.io/images/4602421469315115097.jpg)
![](https://cdn.hackaday.io/images/868341469315141987.jpg)
![](https://cdn.hackaday.io/images/5337721469315182640.jpg)
![](https://cdn.hackaday.io/images/6445881469315358400.jpg)
![](https://cdn.hackaday.io/images/7765381469315492044.jpg)
![](https://cdn.hackaday.io/images/6338531469315507535.jpg)
