powerboost + softpower prototyping
A project log for PiBoy-Zero
yet another portable console! ;-) roughly the size of a gameboy micro, with a 2.2" display
johschneiderJohSchneider 02/09/2016 at 16:560 Comments
breadboard prototyping of the powerboost + battery + soft-power-button circuitry
off (powerboost enable pulled low)
on touch of the push-button -> power on!
the three wires running to the top and out the image will be connected to the raspberry pi, and give it +5V, Gnd and a control/sense wire to the soft-power circuit - that way it will be able so detect further button pushes shutdown properly and cut the power by pulling the control-wire low
further description of the soft-power circuit is available here:
http://www.mosaic-industries.com/embedded-systems/microcontroller-projects/raspberry-pi/on-off-power-controller
