New Shorter USB Micro Board Connectors.
A project log for PiAngle Zero - Not just another Pi Zero USB Hub
A plug-n-play 4 port USB hub for the Pi Zero - No soldering required! Also provides a power source for the Pi
sean-hodginsSean Hodgins 02/05/2016 at 15:100 Comments
Pretty cool update. I found some much better design USB Micro board connections.
They are only one piece instead of two, and they knock about 5mm off the distance of the board!
http://canada.newark.com/global-connector-technology/usb3150-30-130-a/micro-usb-2-0-type-b-plug-th/dp/49Y1723?selectedCategoryId=&exaMfpn=true&categoryId=&searchRef=SearchLookAhead
I'm going to update the design to include these.
