First HEX file downloaded
A project log for eZ80 open-source programmer
AVR-based interface to access eZ80 CPU through ZDI signals - usable as programmer/debugger
hynekhynek 02/26/2016 at 19:510 Comments
After some time, Intel-HEX download is now working. HEX file can be downloaded to RAM, verified and executed. This is good start to begin flash programming.
There is some problem in CDC driver on Windows, some data get corrupted, but on linux it works fine, so I will continue my development on linux; and I will return back to Windows later. Probably, some short delay should be added or shorter packets should be sent but it will come later.
