Inexpensive prototype for large-scale 3D printing in rural environments.
Bend pipe into ring, bisect lengthwise into rings of halfpipe.
Sandwich both sheets between rings.
Drill holes equally spaced through sandwich.
Apply ring of water seal between plexiglass, bolt, and inflate.
If necessary, allow seal to dry.
Deflate and inject water.
View all instructions
SelfCAD
Eric Moyer
Greg Zumwalt
igorfonseca83
Yes, delete it Cancel
You are about to report the project "Project: Lens of Death", please tell us the reason.
