Hi friends,
the latest release supports English and German user interface!
We also incorporated Celsius/Fahrenheit-Switch and lots of other fixes and improvements.
In case of a failure of the online-update, please ssh to your decvice and do the following:
wget https://github.com/WLANThermo/WLANThermo_v2/raw/master/ressources/fix_installation.sh
sudo bash ./fix_installation.sh
After that, you can access webinterface and perform a normal update.
Changelog since last projectlog:
wlanthermo (2.5.2-0) stable; urgency=medium
* FIX: start update as an extra service
-- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Tue, 29 Nov 2016 22:30:00 +0100
wlanthermo (2.5.1-0) stable; urgency=medium
* FIX: added missing probe documentation
* FIX: Pitmaster: Reversed fan control doesn´t work
* FIX: max and min alerts weren´t handled as float
* FIX: display stops working on special chars in channel name
* FIX: wrong names in probe reports
* FIX: restore broken updates
* CHANGE: remove superfluous decimals from values
-- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Tue, 29 Nov 2016 08:44:00 +0100
wlanthermo (2.5.0-0) stable; urgency=medium
* CHANGE: changed startup from SysV-init to systemd units
* CHANGE: moved sudoers entries to seperate file
* CHANGE: i18n of the source code
* CHANGE: new display HMI version with icons
* CHANGE: split alert messages to push/ telegram/ app
* CHANGE: changed valid adc values from x > 60 to 15 < x < 4080
* CHANGE: Nextion HMI Version 2.0
* FIX: Poweroff on shutdown
* FIX: Handle configuration file as UTF-8
* ADD: probe documentation in Markdown format
* ADD: function to recalibrate the NEXTION touchscreen
* ADD: translation to english
* ADD: temperature unit selectable between celsius and fahrenheit
* ADD: probe type iGrill2
* ADD: probe type ThermoWorks
* ADD: probe type ET-73
* ADD: probe type Perfektion
* ADD: probe type ET-735
* ADD: probe type ODC
* ADD: probe type Santos
* ADD: probe type SmokeMAX
* ADD: probe type Weber_6743
-- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Mon, 21 Nov 2016 14:10:00 +0100
wlanthermo (2.4.0-0) stable; urgency=medium
* ADD: WLAN Reconnect über HMI
* ADD: °C hinter den Temperaturen auf dem Display
* ADD: Senden einer Testnachricht
* ADD: Senden einer Pushnachricht
* ADD: Solltemperatur mitloggen
* ADD: Größere Plotgrößen
* ADD: ZeroConf Dienstekonfiguration
* FIX: GPL-Info in info.php
* FIX: Neue configeinträge wurden nicht uebernommen
* FIX: Shutdown der V3 über Button funktioniert nicht
* FIX: Display - Sleepmodus bei Shutdown über Web-GUI
* FIX: pit_man wurde nicht ausgewertet
* FIX: HMI Version 1.8
* FIX: Datenübertragung Display nach Wakeup korrigiert
* FIX: PID Regelalgorithmus verbessert
* FIX: Fehler bei KTYPE an Hardware > v1 behoben
* FIX: Umlaute im Kanalnamen werden angezeigt
* FIX: Neue Sensorparameter
* FIX: Nextion-Display reagiert nicht korrekt auf Shutdown
* FIX: Upload für Nextion-Display an neue Firmware angepasst
* CHANGE: Medianfilter angepasst
* CHANGE: Schleifenzeit der Messchleife korrigiert
* CHANGE: Auslesen der Konfiguration in der Messchleife
* CHANGE: Pitmaster: Anti-Windup II implementiert
* CHANGE: Mehr Sonderzeichen und längere Passphraser für WLAN-Passphrase
* CHANGE: Energiesparmodus für WLAN-Adapter deaktiviert
* CHANGE: Nextion-Display per Default konfiguriert und aktiviert
-- Bjoern Schrader <grillsportverein@bjoern-schrader.de> Sat, 16 July 2016 14:45:00 +0200Enjoy!
Cheers
Armin
armin
