We have the pressure!
A project log for Active Stabilization Rocket System
Use control systems to control and stabilize a Amateur Rocket
jeremy-hallJeremy Hall 08/04/2016 at 00:480 Comments
After a two more days of work I have finished code to get the BMP180 up and running and so far It seems to be pretty accurate (+-1m). I also took the chance and added SD logging functionality to the program so it can record telemetry on the way up.
As always code is on Github.
Godspeed!
