Disconnecting engine
A project log for Toyota MR2 Turbo Engine Repair
I blew up my engine, and am going to remove it, take it apart and fix it. Not really a hack, but it is taking things apart and fixing them.
Scott SScott S 02/07/2016 at 02:200 Comments
The first step to removing any engine is to label things up and disconnect every hose, cable, wire and driveshaft from the engine.
This is the start of that process
