Audio Library - New Project
A project log for Teensy 3.0 & 3.1 & 3.2 & 3.5 & 3.6
32 bit ARM-based boards for use with the Arduino IDE
Paul StoffregenPaul Stoffregen 09/09/2014 at 11:250 Comments
I've created a new project for the Audio library.  If you're interested in using Teensy for audio stuff, this is the one to follow.
http://hackaday.io/project/2984-Teensy-Audio-Library
Or if you're willing to give "beta" code a try, it's all on Github.  Several people have already used it for some great projects, despite the it's unofficial release status.
