close-circle
I resolved the tilt from the video
A project log for Servo-Stock
A Kossel derivative to show off a new PID control framework and command system called the Bowler Communication System.
Kevin Harrington 05/19/2014 at 20:320 Comments
In the video you can see the task space axis tilt to one side as it moves. This was caused by low rigidity in the vertical arms. I added stiffness to them and made the bottom thicker. I also shrunk the pulley for the linear axis to increase the achievable task space resolution.
https://github.com/Technocopia/ServoStock-hw/commit/2baef74771851634ed8c7448e6b900df52d9fbd5
