Aquaponic Controller on rpi zero
A project log for Aquaponic IoT Controller (NFT)
Plug & play controller, plug in regular water pump, lights, air pump and fan to the controller box and use a webapp for control & monitoring
DavorDavor 08/04/2016 at 09:580 Comments
Just to keep you updated, I'm working on moving the project to rpi zero that will significantly lower the cost of this project. And adding some new features like db logging and ph, humidity, water temperature monitoring.
