The Badge design requirements are as follows
PCB : 2 layer 8 mil minimum trace with and spacing
Size: No greater than 50m x 50m
Thickness: 1.6mm
Assembly: Single Side SMT (minimal PTH hand soldering if required under 10Pins)
BOM: <£10 inc. assembly @£0.03 pp
Features Required:
rounded corners
some method of attachment
only a computer required to reflash. (ie. no external FTDI type board)
Display
accessible inputs (ie. tac switch, joystick ect.)
optional onboard power attachments
optional sewable
Ai-Thinker
matt venn
fr.shirvan
meybe add keyboard (simple t9 4x4 buttons is ok) and screen?
or morse alphabet (like https://www.kickstarter.com/projects/246632126/fogo-adventure-gadget-walkie-talkie-gps-flashlight ) . Definitely power is important. meybe step up power from 1.5V (for example AA) or 18650 from flashlight
meybe mini solar panel?
