Testing the Flip-Dot Display - Success
A project log for Networked Low Resolution DMD Projectors
WiFi networked electro-mechanical 7x7 pixel flip-dot displays as giant DMDs (Digital Micromirror Devices) for low resolution projection
michael-shaubMichael Shaub 02/21/2016 at 23:320 Comments
Date: 2/14/2016
I tried alterations to the sample code until I got the flip-dot display to act more predictably.
Below is my revised code for the display with a little extra to automatically count up columns and rows:
/* Simple Serial ECHO script : Written by ScottC 04/07/2012 */
/* Stage 2 : Delimiters */
/* Adapted for LinkSprite V3 and AlfaZeta flip-dot display  */
/* by Michael Shaub 2016                                    */
/* Use a variable called byteRead to temporarily store the data coming from the computer */ //refresh all panels //0x80 0x82 0x8F int frameDelay = 250; //pause 400 ms between frames being sent to the board int counter = 0; int rowCounter = 0; int row1 = 0; //hold variable for row1 int row2 = 0; //hold variable for row2 int row3 = 0; //hold variable for row3 int row4 = 0; //hold variable for row4 int row5 = 0; //hold variable for row5 int row6 = 0; //hold variable for row6 int row7 = 0; //hold variable for row7 String rowString = "B1101010"; int rowArray[ ] = {0,0,0,0,0,0,0}; void setup() { // Turn the Serial Protocol ON Serial.begin(57600); } void loop() { //header, Command, Address, Data, End Character (0xFF address = ALL BOARDS) if(counter > 7){ counter = 0; rowCounter++; } if(rowCounter > 7) rowCounter = 0; byte test_allWhite[]= {128, 136, 255, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x8F}; byte test_allBlack[]= {128, 136, 255, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8F}; byte refresh_all[]= {0x80, 0x82, 0x8F}; //Serial.write(test_1, 116); //Serial.write(test_allWhite, 116); //Serial.write(test_1, 116); //Serial.write(refresh_all, 116); //row3 = byte(B1111010); for(int j=0; j<8; j++){ //set values to match counter, should flip dots one by one across if(j == counter){ rowArray[j] = 1; //set to 1 }else{ rowArray[j] = 0; //reset value to 0 } } /* if(counter == 1){ rowArray[0] = 1; } if(counter == 2){ rowArray[0] = 0; rowArray[1] = 1; } if(counter == 3){ rowArray[1] = 0; rowArray[2] = 1; } */ row1 = 0; row2 = 0; row3 = 0; row4 = 0; row5 = 0; row6 = 0; row7 = 0; for(int i=0; i<8; i++){ int a = rowArray[i]; int b = a << i; //bitshift the value the number of positions equal to the digit switch(rowCounter){ case 1: row1 = row1 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; case 2: row2 = row2 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; case 3: row3 = row3 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; case 4: row4 = row4 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; case 5: row5 = row5 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; case 6: row6 = row6 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; case 7: row7 = row7 | b; //bitwise OR addition of the "b" value to the existing "row3" value break; } } byte test_2[]= {0x80, 0x87, 0xFF, row1, row2, row3, row4, row5, row6, row7, 0x8F}; Serial.write(test_2, 116); //Serial.write(test_1, 116); //Serial.write(refresh_all, 116); delay(frameDelay); // wait for a second counter++; /* row1 = counter; row2 = counter; row3 = counter; row4 = counter; row5 = counter; row6 = counter; row7 = counter; */ }
