This is a rover that I am going to build and test. Gonna try to only use raspberry pi stuff for this (not including the frame)
Create a page for your hackerspace and your members
Yes, delete it Cancel
You are about to report the project "Rover(beta)", please tell us the reason.
Are you sure you want to remove yourself as a member for this hackerspace?
Hackerspace owner will be notified upon removal.
