Works with Pi Zero W 2!
A project log for "Solar Pi Platter"
A Li-Ion charger for Solar or USB with PMIC/RTC, 5V boost converter and USB Hub that can run Linux for only $5 more!
dan-julioDan Julio 12/17/2021 at 16:410 Comments
The Pi Foundation must have noticed that this and other boards were using the test pads on the bottom of the Pi Zero for expansion products.  The Pi Platter works with the new Pi Zero 2 W!  Makes a perfect expansion/battery-backup board with a 5.1V 1A charger and 4.4 Ah battery.
