Expansion, expansion, expansion
A project log for R-Kade Zero
R-Kade Zero + Raspberry Pi Zero = Tiny Video Gaming System
tonydTonyD 03/15/2016 at 21:373 Comments
I've been thinking about making R-Kade Zero more usable, more expandable. So I'm planning on adding a small expansion interface.
This expansion interface will have a SPI and I2C interfaces on a set of female pin headers located on the bottom PCB side and near the top edge of the PCB.
The SPI interface will allow us to add a LCD panel so R-Kade Zero becomes a hand held portable platform. Either a 2.2" or 2.4" LCD panel should do.
The I2C interface will allow us to use a touch screen controller if the LCD panel has one.
Both interfaces should allow us to use accelerometers sensors and such like, opening up some really interesting possibilities.
TonyD wrote 03/15/2016 at 23:43 point
If you're in the Newcastle town centre on a Wednesday night pop in to Maker Space for our Open Evening and I'll give you a demo
http://makerspace.org.uk/
TonyD wrote 03/15/2016 at 23:41 point
Thanks Craig
Craig Hissett wrote 03/15/2016 at 21:44 point
This would be a cracking addition - can't wait to see how it turns out!
With i2c you can add all sorts to it. I look forward to seeing what you come up with :-)
