Painting Crow
A project log for Crow from MST3K
I built Crow from Mystery Science Theater 3000 for my sister's 2015 Christmas present.
kenneth-zabornyKenneth Zaborny 02/28/2016 at 17:460 Comments
Crow's paint is even more difficult than Tom. It's a two stage process with a shiny gold base and a lime gold metallic candy coat. Too many candy coats and you'll end up with a too dark, incorrect tint. There's also a flat black used for all "inner" pieces.
The first step is to get every part coated with the gold base. When you do the lime gold metallic coat you want to hit all the parts with the same number of coats at roughly the same time. Temperature, humidity, and flash times all contribute to the color fastness.
Before:
After:
Comparison:
You can see how much of a difference the candy coats can make.
