Breaking deeper into the bulb was harder because the inner casing was metallic but it was nothing a pair of pliers couldn't handle. Under the metal was some soft gray material probably insulating the component and/or helping remove the heat. To be honest I'm not that sure.
After removing this on pagehttps://kischconsumerlaw.com/ , some more electronic parts were exposed. This is definitely an ESP8266 of some kind
