IR Detection and comunication
A project log for Dtto - Explorer Modular Robot
Modular self-reconfigurable robot, focused on all-terrain search and rescue operations using bio-inspired locomotion mechanisms
albertoAlberto 07/20/2016 at 19:470 Comments
Hello!
I'm working on an infrared system to add the auto-location capacity to the robots. The first test prototype shows that modules can detect each other from about 3 meters apart, and they can detect aproximately where is the other module located. For this "long range" detection, a modulated IR signal is used.
When they are close (30cm), a non modulated detection is used. The receiver looks where is the max intensity of infrared light is and goes there.
This is the test unit.
Hopefully by the end of this month we will have the results!
Thanks
