Building Test Chassis
A project log for Blinkenrechner
Computer based on a homemade 8-bit CPU
grant-giesbrechtGrant Giesbrecht • 08/11/2021 at 17:53•0 Comments
When a critical mass of boards was reached, it became unwieldy to assemble my computer on my lab bench. So I thew together a basic chassis to hold the boards. When the electronics are finished I plan to build a frame from extruded aluminum, but I don't need something that nice just for testing. So here's the test chassis:
Test Chassis
The basic plan is simple - bolt most boards to the plywood base and mount the indicator/control panels to the front verticals.
Front Panel
Control panel and blinkenplatte installed!
Front panel cabling
Lots of ribbon cables. Last I counted, to connect the PCBs I have ready to test will require 443 Dupont cables.
