Become a member to follow this project and don't miss any updates
Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, with a network interface used to centralise data.
28 165 201
Share on twitter   Share on Facebook
This project was created on 06/29/2014 and last updated a day ago.
Description
The uRADMonitor is a completely assembled and functional radiation dosimeter unit. In the current models, the radiation detector is a Geiger Muller tube. The electronics provided are self sufficient: there is a fast microcontroller, a precision regulated high voltage supply, a digital counter and a network interface (Ethernet). The detector works by itself, while consuming very little power, measurements show only 0.8Watts of power! It could almost run on a single AA cell for hours, or it could easily be powered by a solar power source.
While the hardware is globally distributed , the second component of the project - the server is a centralised NODE, receiving the data reports. The uRADMonitor sends small packets of data every minute, so we have an excellent resolution to the measurements.
What started as a hobby project with just a simple Geiger Clicker, has now gone digital to global level, and the first units are already running: http://www.uradmonitor.com . Done as DIY.
Details
In the beginning there was the passion for technology. I decided to start a blog and write about the things I’ve built. I was more into high voltage, physics and various experiments, cool, but with little or zero use to those around me. Then I decided it was time to build something useful, to put my time and energy into something that would eventually come to do good. I already had the high voltage inverters and a few Geiger tubes in my toolbox. In just a few minutes my first Geiger counter was clicking indicating radiation detection. It was early 2011.
As a software engineer, I found microcontrollers exciting, and easy to use. I didn’t learn electronics in school, it was something I acquired during my spare time activities. But an effort done with passion overcomes obstacles easier. With my new advances in electronics, I decided to build a radiation monitoring station, with an Ethernet interface to have it function in an automated fashion by pushing data online for anyone to view. Slowly, the idea I was looking for, was shaping into reality.
The station, named uRADMonitor (from micro radiation monitor), quickly caught local press attention. It was featured in online and local publications, and I even had the chance to talk about it on TV.
Pushing things forward I got to learn about PCB design, tiny SMD electronics and hardware bugs (worse than any bugs known to a software developer). It was a long road of finding mistakes and perfecting the design. Some of that is documented in multiple posts on my blog and progress can be tracked there. But finally, in October 2013, precisely one year after my original uRADMonitor station, the first prototype for the new distributed network of radiation detectorswas seeing the daylight and passing the first tests with good results.
This is how uRADMonitor began, in an effort of building a distributed global network of detectors, calibrated to the same reference to offer consistent radiation measurements regardless of location, to function autonomously and use very little power while pushing the data online to the centralised webportal and to be as plug-and-playable as possible requiring the user to only plug in the power cable (5V DC) and the Ethernet cable (for Internet access). All the rest is done automatically: registering to the network for an IP via DHCP, accurately measuring time and radiation pulses and finally sending everything out to the server.
August 19, Stage 2 Updates:
The system design document:
Here is a presentation video
A previous code revision is available as open source on Google code. Use it as an initial reference. The final code will be released when this project reaches a stable state.
Probably this is one of the best examples of Connected technology, combining the software with the hardware like poetry, going from microcontrollers to Geiger tube and high voltage inverters, coding in embedded C up to PHP and SQL. Hardware dosimeters to do the hard work, and webpages or Android phones to show the data, as the radiation measurements will also be available soon, via an Android app on the Google play.  Technology interconnected at its best, to serve a useful purpose and help us all (global) stay safer.
September 12, Stage 3 Updates and video:
The uRADMonitor is a digital radiation dosimeter, enclosed in a rugged aluminium case. Designed to function as nodes, in a distributed network of radiation monitors,the uRADMonitor units are working together to achieve environmental radiation surveillance on a global scale.
Connectivity is a key element of the uRADMonitor design. All units are reporting the readings to a centralized server, where anyone interested can evaluate radiation levels all across the globe.
The devices can be employed in local, personal use, when one needs to constantly monitor a particular location. But the true advantage of this technology comes on a larger scale, where multiple units are working together, to help us understand variations in...
Components
  • 1 × enc28j60 mini module Great for opening the internet to microcontroller projects
  • 1 × atmega328p Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Geiger Tube SBM-20 or SI-29BG Russian Geiger tubes made for the military - robust and very accurate
  • 1 × Aluminium Enclosure Rugged enclosure to make the detector indestructible.
Project logs
  • Brisbane, Australia joining the network
    a day ago • 0 comments
    14_09_19_australia
    Unit 12000011 just joined the network from Brisbane, Australia, as the third unit on this continent. The measurements show relatively low radiation levels:
    12000011_values
    And here is a comparison to initial tests done in Timisoara:
    12000011_initial
  • New unit in Arizona
    12 days ago • 0 comments
    14_09_05_header
    The 10th unit in the US is now online from Prescott, Arizona. The average measured radiation level is currently at 0.11uSv/h:
    1200000D
    Very similar to initial measurements in Timisoara:
    1200000D_initial
  • Model A – Production Ready!
    18 days ago • 1 comment
    14_09_01
    The uRADMonitor Project is a network of radiation detectors covering locations all over the Globe. The Model A is the first designed, it is an automated GM detector in a rugged aluminium housing which responds predominantly although not exclusively to gamma radiation. Count rate data is recorded and transmitted continuously via built in Ethernet adapter to the central server of the uRADMonitor network. Real time measurements from each of the units in the network are available on www.uradmonitor.com.
    uradmonitor_model_A_2
    Following months of improvements, tests and verifications, both in hardware and software, the final model A design has been put into production and first batch of test units is now available. These will be used to expand the network even further. The quality of these units is impressive: small in size and optimised for low power consumption, they are ready to keep an eye on the radiation levels as independent radiation monitors.
    uradmonitor_model_A_4 uradmonitor_model_A_3
    This first civilian open network of distributed detectors takes advantage of geographic dispersion, similar design with reasonable calibration, constant autonomous monitoring, all at the cost of very low power consumption.
    uradmonitor_model_A_1
    Getting a unit
    To get a device and join the network, see “Join the network”.  There is also one unit listed on Ebay: http://www.ebay.com/itm/131285294964
View all 34 project logs
Victor Bolshakov wrote 7 days ago null point
Why not use PoE (simplest passive variant)? And why metal case? It will shield same radiation...
Are you sure? [yes] / [no]
radu.motisan wrote 4 days ago null point
I wasn't able to use POE in Model A because of the enc28j60 ready-made module that I was using for the Ethernet interface. But it is possible to use an external POE adapter. For the future models I might be able to add this feature too.
Philip Gladstone wrote 8 days ago null point
Interesting -- what type of radiation are you detecting? I would guess that it is mostly Beta. How thick is the aluminum shielding of the case? I would think that that would stop most of the beta radiation...
Have you done any testing / calibration?
radu.motisan wrote 8 days ago null point
The uRADMonitor is an automated GM detector in a rugged aluminium housing which responds predominantly although not exclusively to gamma radiation.
Nakul Rao wrote 8 days ago null point
Awesome Project!! I am unable to access the website www.uradmonitor.com. Is it down?
I see it is working, can you try again?
Jasmine wrote a month ago null point
Hello radu.motisan, now is the time to add a few more details to your project to give it the best chance of going through to the next round of The Hackaday Prize.
By August 20th you must have the following information on Hackaday Projects:
- A video. It should be less than 2 minutes long describing your project. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs (you've got this covered)
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
There are a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
radu.motisan wrote a month ago null point
Thanks Jasmin, I'll do my best to meet the requirements before the deadline.
Radu
I believe this entry now has everything in place. Thank you for the reminders, both here and on email.
davedarko wrote a month ago null point
I'm just here to drop my kudos! Awesome project, pleasing pictures!
Dreistein wrote 2 months ago null point
Have you thought about powering the whole thing over ethernet? Saves the AC/DC adapter http://en.wikipedia.org/wiki/PoE
yes, that would be a good improvement.
Marius Popescu wrote 2 months ago null point
Awesome project!
I'm curious, do you happen to know a source for buying these russian-made geiger tubes in larger quantities?
yes, Ukraine :)
Adam Fabio wrote 3 months ago null point
Great project Radu! Thank you for entering The Hackaday Prize! We need a global network to monitor radiation - ASAP! If you haven't already, you should check out freaklabs talk at the 2012 OH summit, and his work with Tokyo hackerspace. Great starts there!
Keep the updates coming in - How do you test those Russian tubes to be sure they're still good?
screen Name wrote 3 months ago null point
Nice. Seems like you evaluated the whole thing. Maybe I am blind, but I did nit find an answer to this: Does your current design include a discriminator for evaluating impulses? If yes, I'm curious how it works. I've once used a commercial devie which magically transfers impulses in some gaussian shaped pulse allowing you to cound and evaluate energy. Regards.
radu.motisan wrote 3 months ago null point
There is a pulse counter and it has a discriminator (part of the digital circuit), but it doesn't extract any information on radiation energy.
This functionality is usually implemented with different detectors such as scintillation probes or proportional counters, not geiger tubes (almost ignoring the radiation energy in their geiger plateau: http://en.wikipedia.org/wiki/Proportional_counter#mediaviewer/File:Detector_regions.gif )
If things go well, we might see an uradmonitor also capable of measuring radiation energy somewhere in the future (perhaps using an array of PIN photodiodes). We could then have a hint on the type of radionuclide involved.
ghzatomic wrote 3 months ago null point
Very nice man ... great project ... i hope to help the world with my projects as well as you
Thank you, let's hope for the best!
paolo wrote 3 months ago null point
you can add more sensors:
pollution sensor
co2 sensor
radon sensor
uv sensor
I did for the first station built, see: http://www.pocketmagic.net/2012/10/uradmonitor-online-remote-radiation-monitoring-station/#charts . But for these distributed detectors, I need to keep a balance between costs and reaching the target. What I presented here is the Model A, there will also be a model B, featuring temperature and barometric pressure sensor (needed to estimate altitude).
Victor Cazacu wrote 3 months ago null point
Awesome work Radu! ;)
Thank you!
Mads Barnkob wrote 3 months ago null point
Great to see this project! Most of the other distributed radiation networks is only concentrated in the US with a few measurements from Europe.
I am really looking forward to a greater number of monitors spread around the globe and the possibilities to visualize the data with the google maps API.
Keep up the good work!
Thanks Mads!
bremenpl wrote 3 months ago null point
Hey there, great project :). One thing i noticed regarding projects containing ethernet connection is that ppl still tend to use the enc28j60 chip with an 8 bit mcu instead of a 32 bit mcu with ethernet pheripheral on board.
This isnt an attack on your project of any sort! It was just an outloud thought. I wonder either this trend is going to change anysoon.
radu.motisan wrote 3 months ago 1 point
Most likely yes, as things evolve, despite there being a rather large inertia on change. Personally I opted for this combination based on previous experience, and for this project there so many obstacles - I had to choose things I knew they would work straight ahead, where possible.
