The UFactory Uarm
enkiEnki wrote 04/13/2021 at 11:35 • 2 min read • Like
The UFactory Uarm
Table of Contents
The UFactory Uarm is an acrylic desktop 4-axis robot arm which was funded on Kickstarter. There is some information as well as tools on the manufacturer side (http://ufactory.cc/), however here I'd like to gather some of the less obvious pieces of information that I found while playing with this device.
uArm_Metal_Detail_Info&Specifications_en.pdf
uArm-Metal-Developer-Guide.pdf
These are both manuals for the metal version of the original UArm sold via Kickstarter. The second one (the developer guide) comes from the ufactory.cc site directly, but I decided to mirror it just in case.
The UArm Metal is different than the one I have but it's mechanically very similar and basically has an upgraded controller board which is more integrated and not just an Arduino + shield sandwitch. You can find information about the servo parameters which is useful if you need to find replacements. I had to because one of my servos got damaged and I couldn't find the exact servo that they used.
1 Servos
The servos used (marked UFactory US D150A) are identical to popular TowerPro MG945 servos (TowerPro may be an OEM for those) and can be successfuly replaced with them. See photo below:
The hub has an identical size and amount of teeth so even the original acrylic arm fits perfectly:
2 Documents
2.1 From the original Support site
Original URI Mirror URI Notes
http://download.ufactory.cc/docs/en/uArm-Metal-Getting-Started-Guide.pdf uArm-Metal-Getting-Started-Guide.pdf
http://download.ufactory.cc/docs/en/uArm-Metal-Developer-Guide.pdf uArm-Metal-Developer-Guide.pdf
http://download.ufactory.cc/docs/en/uarm_gcode_communication_protocol_v1.0_en.pdf uarm_gcode_communication_protocol_v1.0_en.pdf
http://download.ufactory.cc/docs/en/uArm-Metal-Packing-List_standard-Kit.pdf uArm-Metal-Packing-List_standard-Kit.pdf
Software (Linux)
http://download.ufactory.cc/tools/linux/pro/uclient_v2.0.zip uclient_v2.0.zip
http://download.ufactory.cc/tools/linux/pro/uarm_assistant_v1.0.zip uarm_assistant_v1.0.zip
2.2 Other places
https://cdn.thingiverse.com/assets/dc/ae/c2/94/d0/Latest_greatest_uArm_Assembly_Instructions_v1.pdf Latest_greatest_uArm_Assembly_Instructions_v1.pdf Assembly instructions for the original Kickstarter UArm
https://cdn.sparkfun.com/datasheets/Robotics/uArm_Vacuum_System_User_Guide.pdf uArm_Vacuum_System_User_Guide.pdf Useful information about the proper use of the vacuum pump. Applies to all UArms AFAIK.
https://cdn.sparkfun.com/datasheets/Robotics/uArm_Learning_Mode_Instructions_v1.0.pdf uArm_Learning_Mode_Instructions_v1.0.pdf Information about an autonomous movement learning & repeat mode. Also has information how to start the calibration mode without the uArm Assistant software.
http://www.ufactory.cc/downloads/source_files/UF_uArm_libraries_beta5.zip   Non working link with uArm control software sources. Looking for this…
https://dl.dropboxusercontent.com/u/37860507/UF_uArmSG.zip   A mirror or rebuild of the above code.
https://www.thingiverse.com/thing:320004   An attempt at reverse engineering the UArm mechanics.
https://github.com/46bit/uarm-quickstart https://github.com/mgrela/uarm-quickstart This looks to be like the original firmware for the robot.
https://github.com/uArm-Developer/UArmForArduino https://github.com/mgrela/UArmForArduino The most recent source code for the UArm Metal
Those files that I could find I archived for your convenience so that they won't suffer the same fate like the source code from ufactory.cc which is already MIA.
Like
