Fronius Symo 6.0-3-M inverter
enkiEnki wrote 04/13/2021 at 11:37 • 3 min read • Like
Table of Contents
The Fronius Symo 6.0-3-M is a 6 kW 3-phase grid-tie inverter that is currently a part of my home PV setup. This is a repository of all of the information I was able to gather on this device, some easy, some other a bit harder to find.
1 Interfaces
Aside the obvious DC and AC inputs the inverter has a number of interfaces for monitoring and integration to different systems.
1.1 DATCOM
The DATCOM bus is RS-485 based and documented in Fronius DATCOM Detail.
1.2 The Datamanager card
The Datamanager card is an optional datalogger and interface card installed in the inverter which allows for it to connect to the internet and have additional I/O interfaces. The Fronius part number of this particular card is 4,240,038,Z and it can be found on eBay if you look for that symbol.
There also exists a different model of the Datamanager card with a PN 4,240,034,Z which I believe is meant for different inverter line (IG Plus).
Some information about the card's capabilities (albeit for an older model) is provided on the Fronius site as document ref 42,0426,0169.
1.2.1 Ethernet
The card has an ordinary 100MBit RJ-45 socket.
1.2.2 WLAN
  1. Fronius Solar JSON API
    The Datamanager card exposes a JSON API which is used by the inverter management page to which you can browse on port 80 of the Datamanager card's IP. There are two versions of the API which provide slightly different features:
    The different APIs are supported based on the software version on the inverter as described in Fronius Solar API Compatibility. Fortunately Fronius seems to be well-organized in that regard and all of the docs have identifiers which are easily found with a simple web search.
    Many people have been using the JSON API to integrate Fronius with OpenHab (https://community.openhab.org/t/reading-fronius-inverters-symo-15-0-3-m-with-modbus-binding/26351/21), and Home Assistant.
    There are also python modules to wrap the JSON requests in an API, for example pyfronius.
  2. MODBUS
    The Datamanager card implements a MODBUS interface via RS485 and via TCP over the LAN. The interface is named "SunSpec" and it may be compatible with the specs from http://sunspec.org/interoperability-specifications/ but I have not verified that. Fronius provides docs for the MODBUS intefrace on their own site also under the IDs of 42,0410,2049 and 42,0410,2108 where stuff is described.
  3. Fronius Push Service
    The Datamanager card can also upload logs to an FTP server and this is called a Push Service. It's documented on the Fronius site when you search for Push Service and find a training document. I have not yet used this interface as well.
1.2.3 USB
The inverter also has a USB port used for firmware update. This process has been already documented by others for example on Youtube.
I have managed to download the currently available firmware files and they appear to be encrypted. They are mirrored here.
2 Other
I found some references to using MODBUS for Fronius inverter monitoring in the EU SHAR-Q project paper.
3 References
Fronius ref Description Link Notes
42,0410,2011 Fronius Solar API V0 https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42%2C0410%2C2011.pdf
42,0410,2012 Fronius Solar API V1 https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42%2C0410%2C2012.pdf
42,0410,2049 Fronius Datamanager Modbus TCP & RTU https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42%2C0410%2C2049.pdf
  SETTING UP THE LOCAL FTP SERVER https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/SE_OI_Setting_up_the%20local_FTP_server_EN.pdf
42,0426,0169 Fronius Datamanager https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42%2C0426%2C0169%2CEA.pdf
42,0410,2108 Fronius Datamanager 2.0 Modbus RTU Quickstart Guide https://fronius.com/~/downloads/Solar%20Energy/User%20Information/42,0410,2108.pdf
42,0426,0191,EA Fronius Datamanager 2.0 / Fronius Datamanager Box 2.0 https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42,0426,0191,EA.pdf
42,0410,2020 Fronius Solar API Compatibility https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42%2C0410%2C2020.pdf
42,0410,0968 Fronius DATCOM Detail https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42,0410,0968.pdf
  Numeric fault codes https://review.solar/fronius-inverter-fault-codes/
  Storage capacity sharing over virtual neighbourhoods of energy ecosystems https://cordis.europa.eu/project/id/731285
Like
