Analog way to delay closing a circuit?
David Shamblin wrote 07/14/2015 at 02:59 • 2 pointsI have a button that when it is pressed will activate a video. When it is released, it closes another circuit which "stops" the video (actually switches to a blank video). I want this stop to be delayed so that if there is a quick, non-committed lift up on the button, it won't switch immediately. Is it possible to do with a RC circuit?
You can use just a resistor and a capacitor (schematic: http://www.espitallier.fr/vrac/Ex1.png). When the switch is pushed, the output signal goes immediately to 0V. When released, the RC filter will delay the signal.
edit: I put the schematic in png format
This is exactly what I was looking for. Thanks so much.
Perfect job for a 555 IC (or 556). Can also be done with a capacitor, couple of resistors and a transistor.
Sounds doable... maybe a 555. Not sure how you're going to detect a "quick, non-committed" button-release vs... what's the alternative?
Thanks for your suggestion. The project I'm doing this for is the cause and effect device on my page. The large switch plate button that I'm using has a micro switch. The idea is that the video will play for the kid if he holds the button down and will stop if he lifts it up. But I don't want it to turn off if he is just shifting his weight or whatever and lifts up on the button briefly.
