PT4115 LED Driver Datasheet
daenorthughdaenorthugh wrote 12/24/2021 at 10:01 • 1 min read • Like
Product Overview
The PT4115 is a continuous conduction mode inductive step-down converter, designed for driving single or multiple series connected LED efficiently from a voltage source higher than the total LED chain voltage. The device operates from an input supply between 8V and 30V a and provides an externally adjustable output current of up to 1.2A. Depending upon the supply voltage and external components, the PT4115 can provide more than 30 watts of output power.
This blog will introduce PT4115 systematically from its features, pinout to its specifications, applications, also including PT4115 datasheet and so much more.
PT4115 Features
PT4115 Pinout
The following figure is the diagram of PT4115 pinout.
  PT4115 Pinout
PT4115 Applications
If you want to know more about PT4115, you can read its datasheet.
Like
