LT1014 Op Amp Datasheet
daenorthughdaenorthugh wrote 01/06/2022 at 02:47 • 1 min read • Like
Product Overview
The LT ®1014 is the first precision quad operational amplifier which directly upgrades designs in the industry standard 14-pin DIP LM324/LM348/OP-11/4156 pin configuration. It is no longer necessary to compromise specifications, while saving board space and cost, as compared to single operational amplifiers.
This blog will introduce LT1014 systematically from its features, pinout to its specifications, applications, also including LT1014 datasheet and so much more.
LT1014 Features
Input Voltage Range Extends to Ground
Output Swings to Ground While Sinking Current
5mA Load Current: 1.5 Million Min
17mA Load Current: 0.8 Million Min
LT1014 Pinout
The following figure is the diagram of LT1014 pinout.
LT1014 Pinout
LT1014 Applications
If you want to know more about LT1014, you can read its datasheet.
Like
