Catnip Electronics LoRaWAN node SMA to U.FL conversion
helgehelge wrote 03/18/2022 at 14:50 • 2 min read • Like
Board
 https://www.tindie.com/products/miceuz/low-power-lora-i2c-rs485-node/
U.FL connector footprint
(note the tab on the top is raised and should not be soldered, and the center pad should not short across the cut gap)
Trace cutting and scrape pattern
(after tinning and wicking for flatness. Some more stop mask came off due to the force with which the wick was pulled over the pads, but this may be rectified when soldering the connector with flux paste. Make sure not to cut into the inner layers. Cutting technique:
Finished modification
Like
