Unlike a circuit breaker, all fusible links can't be reset and need to be replaced once it is blown. Take the following guidelines to replace it by yourself.
Materials to prepare:
- New and Proper Size Fusible Links
- Wire Cutter
- Wire Stripper
- Heat-shrink tubes
- Solder
- Soldering Gun
- Heat Gun
- Wire Crimps
- Dismount the negative pole of the battery
- Cut off both ends of the blown fusible links from the main wire harness
- Strips the ends of the new fusible link for 1-2 inches
- Blend the stands of copper of one end of fusible links with the main wire
- Puts crimps onto the connecting point and solder it to build a stronger connection
- Slide the heat shrink tube to cover the joint area
- Use the heat gun to fasten the heat shrink tube
- Repeat 4-7 for the other end of the fusible links
(Originally posted on Easybom)
