Should have started a project, lol but here we are with the last revision of the Single Sided PCB. now only one micro SD socket and two different adapters.
The model of micro SD socket looks like this
The micro SD socket adapter is usually shipped with the header pins out, hence it can be mounted facing up
The SD/MMC card adapter on the other hand is usually shipped with the pins assembles so it must be solded upside down.
