Got some time today to investigate the behavior of the original circuit, as well as the fix I have proposed.
I don't have one ACT chip, unfortunately, only got my hands on a 74'00 from HC, HCT and LS families.
Used the s_ntap program by Guillaume 'Aoineko' from MRC.
As predicted neither one of the three chips is beefy enough to win the fight against the open collector gate inside the MSX, and because of that the software can not "see" on pin 7 the inverted output from the signal on pin 8.
Then I patched the software to keep pin 7 high during the detection routine.
It takes two bytes on CKNTAP function and one byte at CHECK function.
CKNTAP: di ld b, #0 ; b=Max Player ld de, #0xBF0A ;#0xBF00 <-Here call CHECK ; Port1 Check ld c, a ld e, #0x4A ; #0x40 <-Here call CHECK ; Port2 Check rlca or c .... .... CHECK: call PORSEL inc b and #0xCA ; #0xC0 <-Here out (0xA1), a ; 6,8=L 7=H ex af, af' ;' ld a, #14 out (0xA0), a in a, (0xA2) and #0x20 ; 7=H ? ret z .... ....
After that, success..
The program can identify a Ninja-Tap connected with either logic family tested.
And it works with either Ninja Tap or Shinobi Tap feedback loop
Here's the photo of the setup:
